Thread: Brake upgrade
Old 02-28-2005, 03:05 PM   #7
JFP in PA
Thumbs up
The easy way to convert a base to S braks is with the Brembo kit (~$3,000). Direct bolt on, no hub swaps or any other nightmares. I've done three, the Brembo Kit has everything you need. Trick to the kit is it has specially machined rear rotors that work with the base ebrake system. No fuss, not bother and replacement parts are readily available from Brembo.
