Old 04-16-2008, 05:25 PM   #10
blue2000s
Porscheectomy
Originally Posted by insite
blue is right, and the worst culprit is aluminum on aluminum. this will seize more or less immediately. you are correct that ss and aluminum + salt more or less make a battery; anti-seize won't help much there....paint might.
You can use zinc-plated or nickel-plated steels against each other because the plating tends to act like a lubricant.
