Old 04-16-2008, 02:17 PM   #2
Kirk
Originally Posted by insite
you might be thinking of the brace that doesn't use rod ends, just holes drilled in a bar. in this case, any chassis twist could cause a torsional fracture. better to use rod ends. blink's design looks right on the money.
Have people had problems with the solid bars breaking? I don't normally check out Porsche Pete's board, but I did some searches over there and didn't find anything. I haven't seen anything on Renntech or Babblers either... Way to go Blinkwatt, starting awful rumors!
I think the setup that blue2000s came up with looks good. I would caution you on one thing though - use anti-seize on the threads of the heim joints. You're using a steel heim joint in an aluminum bar. Dissimilar metals don't get along well and will eventually fuse together. That's why I personally use steel heim joints with a steel bar and aluminum heim joints with an aluminum bar. Now this may not be a big concern in this application though if you just install the bar, set it, and then never touch it again. I'm just saying this is something to consider.
Kirk is offline   Reply With Quote
