Old 04-16-2008, 11:22 AM   #3
John V
Just did my first test and tune with the 996 GT3 front sway bar and 245/285 Kumho V710s on stock wheels. -.7 degrees front camber, -1.2 degrees rear, zero toe front and rear. Bar was set to full soft. On cold front tires, lots of understeer. But once the tires warmed up, the car was very well balanced. No understeer to report except in very tight turns. Slaloms are brainless now. Floor it and steer. No more inside wheelspin in slaloms. Nice lift-throttle oversteer characteristics, and neutral handling on-power.
31psi front and 33.5psi rear on 40-run-old V710s with a bunch of heat cycles on them. If it stays dry this weekend for our first local event I'll get some good data on how the car is relative to some of the best drivers in the country.
John V is offline   Reply With Quote
