Old 04-16-2008, 06:48 AM   #4
renzop
If you are fat, maybe it's your belly hitting the horn button :-)
While I know its not your problem, here's an amusing little story:
I once had a car that had the ignition on the steering column. I also had just a few keys on a plain keyring. Every once and a while the other keys on the ring would flip over the top of the ring under hard braking. If they flipped just right one key would flick into a gap in the plastic around the steering column. It would then short out the horn button and the horn would come on and stay on. The first time this happened it took me about ten minutes to figure out why the horn was going off :-(
renzop is offline   Reply With Quote
