Your Battery is located under the Hood.
Open the Hood and look straight ahead. You'll see a large black rectagular plastic piece. This is the Battery Cover. On each side, you'll see a knob, turn them 90° and lift. Then, pull straight forward.
There is a 10mm nut on each cable connector. The Battery also has a hold-down on the passenger side which needs to be removed to remove the battery - 13mm hex head. Also, you'll see a clear vent tube on the passenger side going into the side of the battery - this just pulls out.
