Thread: Engine Codes
Old 04-15-2008, 09:02 AM   #4
KY Boxster
Originally Posted by tboyer
Welcome to the board, could be as simple a vacuum leak, I had that code when one of the rubber sleeves that sits after the throttle body had a slit in it where the metal strap connects. My issue had my idle jumping between 600 - 1200 RPM though, so, it was noticeable.
Is your idle bouncing around?
Is the car running rough at idle?
It runs real rough when it's first started in the morning....this morning I could barely get it going....albeit it was 30 degrees, but it still wouldn't idle for about 5 minutes. Then it was rough for another 5, then it did okay. I cleaned the MAF today and will see what happens. I looked at the metal strap you described and didn't see anything, but i will continue to monitor it.
Thanks for the info.
KY Boxster is offline   Reply With Quote
