Old 04-10-2008, 07:55 PM   #13
J-RAD
Originally Posted by poopoopaul
The cigarette lighter trickle charger works too, but that just means you'd have to wait on it if you order it.
Agreed. Run to Target, Sears, or your local auto store and pick up something like this:
http://www.target.com/Black-Decker-Battery-Booster-BB7B/dp/B000H774BY/sr=1-16/qid=1207882187/ref=sr_1_16/601-2334779-7179315?ie=UTF8&index=target&rh=k%3Abattery%20charger&page=1
You only need enough to get the power necessary to pop the hood, then use cables and jump it. You'll be on the road in an hour. You could also leave the cigaretter charger on long enough to start the car if you want but it will take a bit longer.
And next time, when you park your car for the winter, leave the hood cracked open.
p.s. I did the same thing a year or so ago. Just be happy you didn't disconnect the battery (like I typically do) and close the hood tight. That would really suck.
2000 Boxster S
http://img.photobucket.com/albums/v2...terSAvatar.jpg
"It is better to enter a corner slow, and come out fast, than to enter a corner fast, and come out dead." - Sir Stirling Moss
J-RAD is offline   Reply With Quote
