Originally Posted by adamhoff66
Thank you all for your advice. I removed the seat and control unit. there was still water in it ...What do you guys think the likelihood the ignition starter switch is shot coincidentally since I basically have all other power except door locks and windows? Thanks in Advance
Adam(?)
1) Others will scoff, but I drilled a hole in the floor down stream from the thing, primed the exsposed metal. Fixed the origional leak to but I'm ready for the next.
2)That security box when on the fritz causes all sorts of bazaar problems. Thats because just about everything electrical goes through it. Hold on to you ignition switch money till you straighten out the black box.
Regards, PK
