Also a likely culprit is the microswitch located in the hole for the Top latch on the windshield header (which is what I'm betting on). This switch gets stuck and disables the motor drive for the Top.
Take a small, non-conductable rod or stick and push it in and out of the opening for the Top Latch to work the switch free. It could take several goes to be sure it's loose. You may also be able to hear it click. See if that doesn't get you going.
