Old 04-08-2008, 08:59 AM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by Lil bastard
I think it's time to replace the MAF. Aside from the Hot Film type Mass Air Flow Sensor, this part has the Intake Air Temperature sensor integrated into it.
You cannot fix this Intake Air Temperature sensor by cleaning the MAF. If it is wrong, all you can do is replace it.
You can test the Intake Air Temp sensor, which is really just a 'thermister' - it changes it's resistance to a constant electrical current based on temperature.
Remove the MAF and connect an Ohmmeter to pins 1 & 3. You should be seeing 2.3-2.7 kΩ @ 20°C (68°F). Any other value and the MAF must be replaced.
BTW, a high Intake Air Temp would cause the DME to lean out the fuel supply, not enrich it because Hot air is less dense than cool air. Seeing less air mass, the DME would reduce (not increase) the amount of fuel supplied.
Well that makes sense. Im just glad the torq is back cause Chevron across the street is at 3.99 for super and with the MAF plugged in, the boxster was just ********************t*ng gas like a greengo after eating his first enchilada. Thanks for the data for the Ohm meter, I've wanted to check it but didnt know what values i should be looking for. Ill have to get some batteries for the Ohm meter before i can do that.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
