Old 04-07-2008, 09:35 PM   #1
boostiality
Finding info on these motors is hard to come by. So I'll do you a favor and let you know what I found.
Code is going to be M96. It varies as it's used from boxster, to caymen, to NA Carrera.
Compression ratio: 11.0:1 around there depending on which application
Injector size is 23lbs/min
You can tell which motor has a butterfly valve as it sits within the 2nd chamber of the intake manifolds of 2.7L and later motor cars.
VarioCam is also used, with VarioCam Plus in later cars.
boostiality is offline   Reply With Quote
