Old 04-06-2008, 07:35 AM   #2
Topless
Track rat
Topless's Avatar
Doesn't look too bad. I've seen much worse. The pleated side is the clean side and should always look perfect. No dirt ever. If you are chasing a CEL 1128, 1130, changing the air filter and cleaning/replacing the MAF are a good first step. Also look for loose vacuum lines around your intake between the MAF and intake manifold.
