Old 04-05-2008, 01:50 PM   #11
Lil bastard
Lil bastard's Avatar
Originally Posted by rd400rz
You said in your earlier post it was the clutch switch are there two switches there must be I will check it how do you kno if it is bad how do you test it thanks or should I just replace it I kno its not the fuse
Use a DMM (Digital Multi-Meter) with a continuity tester and set to continuity, attach DMM leads to each lead on the switch, press the switch 'on' and listen for a beep, no beep - switch is bad.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
