Originally Posted by rd400rz
Brake light switch where is it located is it under the brake pedal ?
Yes it is and as usual TP is right it was my brake switch which makes sense when you consider it terminates the cruise control. The switch has a plastic plunger actuated by the arm of the brake pedal. To remove the entire switch you turn it and it comes out of a hole it snaps into, it's a twist lock operation. There is a really good pic of it on the 986 catalog that I downloaded free from this site. I tried to pull just that pic out and link you to it but as far as I can tell adobe doesn't support that function.
