Old 04-04-2008, 07:43 PM   #6
chaudanova
Originally Posted by chitowndad
So I guess I don't fully understand desnorkling... Is desnorkling the process of removing the tube that runs from the air box to the intake throtte body?
If you remove this tube, how do you filter the incoming air to the throttle body and MAF? If you remove this are you running the air unfiltered to the throttle body?
Confused,
-Steve
Steve, maybe this will help clear things up just a bit for you:
Outside air --> side vent --> Snorkel tube (to be removed) --> Air Box/Air Filter --> MAF/Intake tubing --> Throttle body/plenum --> Intake Manifold
This is the simplified general idea, though hopefully you can visualize slightly with this in mind.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
