Old 04-03-2008, 09:14 PM   #3
boxs2000
wow... you got lucky passing. I believe the person that did your smog was in a hurry and did not do a visual test. Also if you eliminate the first set of cats on an S wont it cause you c.e.l light to come on (because the 02 sensors are on the first set of cats) and if that happens you will fail smog test.
boxs2000 is offline   Reply With Quote
