Old 04-03-2008, 08:42 PM   #2
chaudanova
Originally Posted by chitowndad
Guys,
On the 911 you can buy an after market high-flow filter that attaches directly to the MAF sensor. Is there something similar for the Boxster? The reason that I ask is if I fully understand desnorkling you remove the air tube to the MAF and if you do this aren't you running w/o an filter element or do I not fully understand desnorkling?
I'm concerned about desnorkling and not having a filter element before the MAF sensor and if they have this for the 911 why not the Boxster? Make sense?
Any insight is appreciated.
Thanks,
-Steve
Steve, I think you have a slight misunderstanding of the desnorkeling. The 'desnorkling' is before the airbox/filter and maf. When you desnorkle, the stock airbox and air filter are left alone.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
