It depends on if it's a Canadian car or what mod was done to turn on the DRL. I have a 2001 Canadian spec in the shop with litronic that uses the factory relay for DRL and everything is on when it's running.
I've also installed universal DRL kits that only active the low beam lamps when the ignition is on.
