Old 03-28-2008, 07:02 PM   #3
porscheracer01
Originally Posted by CJ_Boxster
that's no biggie. Its because the ebrake switch is on its last leg and that has to work for top to go down or up. Try pulling the ebrake lever up and down till u see the brake light turn on, on the dash. Once it lights u can lower or raise the top.
Got it, I need to replace the ebrake switch but P dealers are close Sat/Sun...in case the above method does not work is there a way to close or open the top without using the handbrake? a short cut?
thanks again,
porscheracer01 is offline   Reply With Quote
