Old 03-26-2008, 10:41 AM   #21
Lil bastard
Lil bastard's Avatar
Originally Posted by D.L.
Not to hijack this thread, but my coolant levels are sometimes low causing the light to blink on the dash. I think I may have a small leak or a bad cap because I find A LOT of condensation above of the coolant area on the trunk. I always thought this was normal due to changes in temperature, but I guess not. Anyways, I always used regular water to refill... Did I mess up the car doing this, or should I use coolant to refill? I also heard that Boxsters use a different type of coolant. Is there special coolant for our cars?
A Lot of condensation isn't mormal. Suspect a bad cap, a poor Bleed Valve seal, a bad hose connection or a cracked coolant tank.
It's OK to top up occaisionally with water (distilled water is best to prevent introducing minerals to the system).
But, each time you do this, you dilute the coolant mix. Porsche specifies either a 50/50 mix of anti-freeze/distilled water, or a 60/40 mix. You don't really want to be <35% anti-freeze or you both increase the corrosion potential and reduce the lubricating properties of the mix.
Over time, topping up with even a little bit of distilled water on a semi-regular basis adds up. You can buy a cheap Hydrometer at most any auto parts store for about $5. This is the little 'baster' which has the little floating balls in it. It tests the specific gravity of the coolant mix and can tell you what your actual mix % are.
The coolant should really be changed every 5 yrs. or so, despite claims from Porsche that it's a lifetime fluid - it isn't.
Use the search function here to find out what brands are, and are not, compatible. There's lots of good info.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
