Old 03-25-2008, 01:03 PM   #10
tracke30m3
The brakes are an easy DIY job.
As for the clutch and RMS, $1500 should cover parts and labor for the clutch at independent Porsche shops. They can easily change the RMS while they are in there replacing the clutch. Oil leaks from the spark plugs can be solved by replacing the plug tubes and O-rings, another DIY job with parts costing less than $100.
I think you should be able to find an independent shop that will tackle the brakes, RMS, clutch, sparkplug tubes for about $2000.
tracke30m3 is offline   Reply With Quote
