Old 03-25-2008, 10:15 AM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by Lil bastard
Well, Yes and No.
If you're stranded or driving a short distance to a repair service, then Yes, you'll be OK.
But, if you're planning anything other than that I'd say No.
In addition from keeping the coolant from freezing, anti-freeze also provides needed lubrication for the Waterpump bearing as well as corrosion pretection. It wouldn't take much driving at all for damage to the pump or corrosion to occur.
Agreed, but he hadn't lost all the coolant in his system, so topping up with distilled water and driving the 30 minutes to the dealer (which was what he was asking if it was safe to do), would be fine. There was a friend of ours who during a 9 hr. drive down to a Boxster event in North Carolina from New Jersey, his old coolant cap let out a huge amount of coolant after stopping. Refilled with (non-distilled) bottled water and went on to go thru the whole 4-day event, and then drove all the way back home, with no issues. Car and water pump are still fine today....
