Originally Posted by tracke30m3
Doesn't the 02 sensor DIY here show using crimp type all weather connectors?
I had to remove the connector and wire from the OEM sensor and splice it unto the generic 4 wire one.
If not crimp type connectors, what should I use? I remember the DIY saying not to solder the connectors.
I don't know why you wouldn't want to solder it except for maybe the high heat environment might cause it to melt.
I would solder it and use heat-shrink tubing.
Not all OČ sensors require a reference sample and not all acquire this sample through the insulation. I'm not sure which the Boxster uses, so this may be unecessary.
