Hate to say it, but I had these symptoms when my coolant tank had a small leak/crack in it. It got progressively worse until I was losing like a quart of coolant each time I shut off my engine. Had to replace the coolant tank, as it had a leak at the bottom of the tank where you couldn't see it, and it released coolant through the bottom of the pass. rear wheel.
It could also be that you have an older version coolant cap. Get a new one at the dealer if the part# on top of the blue coolant cap ends in 00. The updated ones end in 01 or 02. If this is the problem, it's a cheap fix. Good luck.
