The problem is that the Toe links are not short enough to pull the wheel straight after its lowered... Since i had Adjustible Upper Track arms, i just shortened them abit and that solve my Toe problem... But since you have no aftermarket suspension to correct this, go with the Adjustible Toe links, itll correct the shimmy and tire wear issue.
When you lower the car, the Rear Track Arm pushes the lower control arm back alittle cause at normal height the track arm is angled down slightly and so is the rear toe link... and when the car is lowered, Both the Track arm and Toe links are in a more Level position which in both cases increase your toe in.
