When ever you lower the boxster the rear toe gets way too negative and you need Che's adjustible rear toe links to correct it, excessive toe will cause the tires to wear really quickly... I bet when you go over bumps you get alittle shimmy or wiggle from the rear end, huh? Thats because of the excessive toe.
