What's the wear look like? Is the tread still flat but angled or is the inside feathered? If the later then the problem is toe combined with camber. If you zero the toe then th 0.5 front camber should produce very little extra wear and the rear should wear just a little more quickly than stock. I bet you'll find that you have an unhealthy amount of toe.
Regards,
Alan
