Old 03-17-2008, 10:45 PM   #8
lapis986
double sided foam tape and zip ties on the inserts! I cut about a 7" very thin strip and put one on both sides and up toward the clips. drop the windstop back in, slight pressure down and you are set for about 6 months. I took a few small pieces and put them on the tabs of the inserts as well, then added the zip tie- no more problems...
lapis986 is offline   Reply With Quote
