				alignment after lowering w/eibach
			hi folks.
I bought my '01 box S a year ago.  The prev owner said he put on eibachs and bilsteins.  The rear tires wore out quickly, so I got around to checking the alignment (I have a smartracing set up).
In front I have -0.5 deg camber each side.  The adjustment is maxed out, so I can't get it to stock spec.
In the rear I have -1.9 and -2.4 deg left and right, respectively.  I don't have toe #'s yet.
This is a street car and I want closer to oem measurements.  My question is, are spacers available to put under the springs so that the eibachs won't lower the car so much, and allow closer to oem measurements?
