Old 03-14-2008, 10:15 AM   #2
Lil bastard
Lil bastard's Avatar
I'm a little persnickity when it comes to brake service.
Which Mintex pads are you using? Street? Track? Metallic? Non-metallic?
Did you measure your rotors to see if they req. turning or replacement? W/ 37k, you should be OK, but it's always good to check, if nothing else, you establish a baseline for future reference. Ideally, you use a micrometer, measuring several places around the disk and from the center. But, many people don't own one, so a cheap plastic vernier caliper from say Loews or Home Depot used the same way will give you a close approximation.
What did the rotors look like? Shiny/bluish? Dull/grayish?
Did you sand the rotors using a block and #40 grit sandpaper?
Pads work against the rotor in 2 ways. There is the mechanical friction created when/where the two meet, and there is an adhesion between the Pad and Pad material deposited on the rotor - that's the dull/grayish appearance in the rotor.
Bedding-in accomplishes 4 things:
  • It allows the Pads to conform to the surface of the rotors
    It allows the pads to deposit a thin layer of like Pad material on the rotor
    It allows the Pad material to Heat Stabilize
    It allows the Pad to Off-Gas solvents and chemicals absorbed by the material in the manufacturing process.
In terms of adhesion, the old pad material may be incompatible with the new material and not allow it to deposit the required layer. This is why it's good to at least lightly sand the rotors.
To bed-in the pads, there are lots of different opinions on how to do it ranging from nothing at all except easy street driving the first 50-500 mi., to agressive braking, working them hard and getting them hot.
This is the Bed-in procedure published by Mintex for their pads:
Metallic pads such as Mintex require a bedding-in which, when done correctly, eliminates problems that may be encountered when installing high quality performance pads.
First, it is important to inform the customer that metallic pads should not be installed on a vehicle with worn rotors. A soft, organic pad will conform to the grooves in a worn rotor while a metallic pad will not. It is therefore essential to either replace or turn rotors when installing Mintex brake pads.
After installing Mintex pads they should be bedded-in to insure top performance.
  • Accelerate to approximately 40 M.P.H. and apply the brakes with moderate pedal pressure
  • Slow to approximately 5 M.P.H. - do not come to a full stop
  • Repeat this procedure 10 times allowing 1/3 of a mile between stops
Do NOT attempt to bed-in pads by driving the vehicle with the brakes constantly applied. This will damage pads and result in decreased performance
Read these instructions carefully and decide what stretch of road will allow you to safely follow this procedure. Good Luck!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
