Originally Posted by rick3000
The black plastic pieces that fit behind each seat, don't do anything. The seem to add more wind noise in my opinion. You don't really need them, but they show up on eBay occasionally, and so do the windscreens (clear plastic between the seats) if you need one of those. And the windscreen will reduce wind noise.
Strange, cause I have run with and without the black mesh pieces behind the seats for an extended time, and find that there is a pretty BIG difference in wind turbulence at high speeds. I always have the middle windscreen in place, but find that if the mesh inserts are not in, there's still a good amount of wind turbulence. They are ridiculously expensive though. I think someone should offer an aftermarket alternative.
