Originally Posted by raddoc
Actually, the braces underneath are the reason that PDR works so well. They usually heat a putty knife to release the adhesive between the brace and the lid or other panel, allowing the panel to spring back or be easily popped back into shape. Check for a gap after the repair ; I filled mine in with silicone and then painted the goop.
Interesting. I had a small dent in the hood of our Jag which was right behind the bracing. The PDR guy used by the Dealership looked it over and said it couldn't be removed via PDR, but that he'd have to drill and pull it, then fill it and paint it.
This
wizard was very skilled and did some truly invisible work on another car of mine, so I trust he knew what he was talking about.
I found a perfect hood, same color, on CL for $200, so I went witrh that as opposed to pulling, filling and painting which was quoted at $500.
So, I guess it all depends on the dent, location, skill of the
wizard, etc.
