Originally Posted by themperor
Got the car back today from the suspension work!
PSS9's installed and H&R front and rear sways, alignment, corner weighted, 15mm spacers in the rear and 6mm in the front.
Before front was -.3 and rear was -1.5
Cross was 48.8%
Left was 51.8% and rear was 53%
After front is -.5 and rear is -2.2
Cross is 51.2%
Is this camber? Why not more negative camber up front? You should be able to get at leat -2 in the front. Heck, stock you can get, typically, -1.5 to -1.8. Typical alignment has the rear camber only about .5 more than the front. This would also improve handling. With -2.2 rear you may find a need to frequently order rear tires
