Old 03-11-2008, 02:28 PM   #2
edevlin
edevlin's Avatar
"Does this switch require any modification to the existing, or replacement of, the Battery Tray?"
Yes, I started with a temp solution using foam blocks and a home-made strap to keep the battery in place. I eventually got a strap from a 911 Turbo exhaust system and had a strap made as a permanent solution, you can see a pic of it on my webpage.
"Do you need to install longer Battery Cables as with some other type of Batteries?"
No, but its close, there is a little slack with cables, but not much.
"Did you happen to ask them if there are any charging issues for these batteries with the standard 120-Amp Bosch Alternator?"
No, but I have been using their batteries for over a year to good effect.
Ed
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
