Old 03-11-2008, 12:47 AM   #2
blue2000s
Porscheectomy
This isn't hydro-lock. Nothing you've described could have caused hydro-lock. The car will run without a MAF attached at all, so I don't think that was the cause of your problem. Cam timing on these engines is by chain, the chance of the timing running off and the piston smashing a valve is really slim.
From your description, it sounds like either something internal broke off and was loose or the engine ingested something solid.
