Originally Posted by Perfectlap
After a while you learn how to listen to a V1.
The only problem is that the headlights from Inifinti Wagons always show up as Lazer.
It's not the headlights of the Infiniti that is making your V1 alert to laser.
http://valentine1.com/lab/Previously7.asp
Laser False Alarms
Why am I getting laser alarms when I follow some cars?
- J.J., Michigan
Red neon is occasionally used for the CHMSL (Center High Mounted Stop Lamp) on new cars. We know of these models: GM Trailblazer and Envoy, the Lincoln Mk VIII and the latest BMW 3-series convertible.
These lights use a neon-plasma light source. The red lens allows red visible light to pass, and also invisible energy near infrared. The source is powered by a pulsating voltage on a frequency that happens to be similar to the repetition rate of legitimate laser-gun pulse trains. In other words, the CHMSLs have an invisible energy leakage that’s nearly identical to the beam used by traffic laser. If we suppress the interference, we’re likely to damage laser sensitivity.
Another source of alarms: a few new cars have cruise controls that use laser to measure distance to the car ahead. This feature is available on the Lexus LS430, Infiniti FX35 and FX45. This, of course, is real laser, not a false alarm.
