Old 02-22-2005, 07:21 AM   #2
YellowJacket
Send a message via AIM to YellowJacket
Originally Posted by RandallNeighbour
3. This might cause an arguement here, but my mechanic said that replacing wear sensors are not worth it. Regular inspection is just as good and far cheaper.
4. Rotors are not turned on Boxsters, only replaced, and will usually last about three sets of pads, maybe four, according to my mechanic. He said it depends a lot on what type of pads are used on the car and how much hard and high speed braking you do.
Agreed on the brake sensor. Only needs replacement if you wear your brakes to the level where the wear sensor is activated. Regular inspection should prevent this.
And with the rotors -- you are correct -- DO NOT turn the rotors on a European car. They should be replaced when you can feel warpage in your braking, or when a visual inspection shows them to be significantly worn/warped, or every couple brake jobs, whichever comes first.
YellowJacket is offline   Reply With Quote
