Old 03-07-2008, 10:47 PM   #15
blueillusion97
There is another possible solution that i found, assuming micros switch is not a problem you can try this maybe it will help.....with the top up close the door with lowered window then put it up and keep holding the switch in up position for about 5 seconds more. I will try to find some more info about that mirco switch, but mean while i would be very carefull closing the door if the glass is touching the top, you wouldnt want it to break.
blueillusion97 is offline   Reply With Quote
