Old 03-07-2008, 11:01 AM   #13
CJ_Boxster
Send a message via MSN to CJ_Boxster
THis is easy... You microswitch on the door latch (the part that locks onto the body) is malfunctioning, I bet with your door open, you lift your door handle on the outside, the window will drop and then raise up quickly after you let go of it. Ifs thats the case then its a microswitch.
In the meantime before you have a chance to repair it, You can lower your window a little bit before closing the door, then once closed, roll your window up.
You can also try slapping with an open palm, the latch mechanizim on the door. sometimes if its loose wiring it'll get the window to drop the 1/4 inch before you close the door.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
