Old 03-07-2008, 05:50 AM   #11
JackG
Originally Posted by joshua6060
with the windows down, the doors close properly, the door gaps on both side appear to be the same, with the windows up, the passenger side closes properly, the driver side still doesn't close properly, when the window is up on the driver side and you pull the door handle, the window drops down that 1/4 of an inch, but when you try to close the door with the window up, the window sits on the outside of the top and the door won't close all the way without a STRONG push....
I don't mean to beat a dead horse, but the written word can be misleading...
I understand that when you pull the door release, the window drops. What I'm not clear on is: when you pull the door release and open the door, then take your hand off the door and step back, if the window *remains* in the dropped position while the door is open.
If, once the door is open and the door handle is released, the window returns to the up position (not dropped 1/4"), when you try to close the door the exact thing you are reporting will happen.
In other words, the window *must* be in the 1/4" down position when you try to close the door. Even when you're not pulling the door handle to open it.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
