You will probably have to remove the door panel as I suspect one of the wire stringers has detached or a plastic clip on the latch broke off (in which case you'll need to replace it). Be sure to have your Radio code, disconnect the battery, and wait for 5 min. to be certain the side airbag is deactivated before starting.
