Old 03-02-2008, 05:36 AM   #1
gstoli
Sounds like you don't power the speakers (or the amp). Are you sure that the "power amp" leads are at the same position for both units? You could check your fuses too, but it doesn't sound as a blown fuse (since you get power to the source unit). If you swap back your old unit everything works right?
George
gstoli is offline   Reply With Quote
