Old 02-21-2005, 12:11 AM   #1
Jinster
Thanks for your reply, Sir.Rhosisoftheliver.
My OBD2 scanner doesn't give ABS codes. It only gives P codes (DTC, Mode $03) and some "non-uniform core" codes (Mode $07).
The P0740 is all I get at the moment.
I was told that there are 4 speed sensors, one in each wheel. And they all go to the ABS controller which monitors the 4 sensors for consistency.
I have no speed signal visible on the dash at the moment.
I don't think my scanner can read individual speed sensor actual voltage.
Is the solenoid accessible from just under the car or do I have to take apart the tranny? I will try to unscrew/unplug it if it's easily accessible.
Jinster is offline   Reply With Quote
