I ran a 225/275 18 combo and wished I had gone to 245s all around. For me, I like a car to rotate and with the 225/275 combo, it just didn't happen. I won't say if 245s are faster, but they do feel more fun. 245s all around will help reduce understeer, but realize that the Boxster left the factory desgined to understeer - especially with the 205 stock fronts
(plus, understeer is safer and limits lawsuits)...
If you are committed to a "stock suspension" then you will
always chew up the outside edges of the fronts. R comps need at least 2-5 degrees of negative camber and the stock set up only allows about -1.8 at most (unless your car was in a collision
So, an advantage to 245s all around would be to spread that wear evenly around the car by rotating wheel positions.. and then flip tires on the rims as well.
