Originally Posted by schoir
Kouros:
The leak you are describing commonly occurs as a result of one of three causes:
...Regards, Maurice.
Hey Marice,
Still struggling with mine(leak).
Don't get this one though. If water is getting into your door, filling up the whole bottom (quart or 2 ) then over flowing into the car because the thin little plastic skin isn't sealed, I'd think either the water shouldn't be getting in the door in the first place or, it should be draining out the bottom.
If I understand this oft heard diagnosis, I keep thinking that under the best of circumstance, your door would be full of water after a storm.
What am I missing?
Regards, PK
