Old 02-20-2005, 05:02 PM   #5
larez2
I know this is not so pertinent, but my Jeep Wranlger has a setting that let you start the engine with the transmission in gear, and the clutch engaged (not pushed it). It was pretty crazy, just throws you forward when you turned the key. it was for if you were so off camber that fuel could not get to the injectors/engine and you wanted to use the starter to turn the engine over and move the vehicle a short distance...
Larez2
larez2 is offline   Reply With Quote
