Old 02-25-2008, 06:21 PM   #10
blue2000s
Porscheectomy
Originally Posted by CJ_Boxster
Hmmm, i dont know... i dont see that epoxy cracking, i mean nothing touches it, no moving parts either and rated up 2500 psi before point of failure. I can see an airfilter deteriating sooner than the chunk of epoxy but your right about the elbow... does seem safer, But imma stick with the stock elbow its hard inner surface will probably help echo the intake noise alittle better than a softer sylicone elbow.
Heat + vibration + pressure from a hose clamp (if you're using one). I'd be looking for a molded plug.
