Originally Posted by SinnerDC2
I cant get the seat to go down.. its too far up.
are you trying to do this while standing up outside of the car? or while you are sitting in the car?
you need to be sitting in the car. use your weight to push the seat down. if you are still having problems (aka you weigh under 120lbs) then pull the seat forward, and use teh steering wheel to help you force the seat down. FYI... it goes down in an arcing motion towards the rear of the car. if you still can't find someone over 200lbs to help you out. : )
i myself have no problem getting the seat down. : (
