Old 02-19-2005, 07:01 AM   #3
Maxandwill
Info
WWW.EVOMS.COM
Boxster | Tuning Systems | Computer | Exhaust | Intake | Shifter | Transmission | Brakes | Suspension | Wheels | Aero | Lighting | Interior |
Boxster Air Induction Tuning
EVO HighFlow Fresh Air Intake System: Engineered for maximum power and sound. This engineered system eliminates the OEM restrictive airbox and incorporates a HighFlow aFe cone air filter and sealed fresh air chamber. A cone filter has superior air flow characteristics as compared to flat panel filters. The cone filter better shapes the air as it enters through the filter for smoother straighter more formed air. Next, we have CMC machined a MAF housing to the exact tolerances of the OEM housing for precise MAF reading and NO CHECK ENGINE LIGHTS. In addition, the sealed air chamber sections off the cone air filter from the engine compartment so that it can only draw cool outside air for more power. Finally, our system is injected molded from crosslink polyethylene which has the lowest thermal conductivity rating of any single-layered moldable material available on the market today. This is key in keeping intake temperatures low and increasing power.
Boxster HF Intake Instructions
HighFlow kit
Model Year Power Description Part # Price Dyno
Boxster S 3.2L 2000- 8-10 HighFlow air Intake System INTK98632HF $379 DYNO
Boxster 2.7L 2000- 8-10 HighFlow air Intake System INTK98627HF $379
Boxster 2.5L 1997-1999 8-10 HighFlow air Intake System INTK98625HF $379
EVO QuickFlow Air Intake System: Due to strict noise regulations, the Porsche Boxster/S is equipped with a sophisticated two-stage resonance induction system. The air intake tubes from the OEM airbox to the throttle body incorporate resonance chambers. These "dead air" chambers impede airflow and reduce intake sound. By installing the "QuickFlow™", the OEM restrictive resonance chambers are eliminated which allows for better air flow and sport engine sound. The QuickFlow™ Induction kit utilizes the OEM airbox but replaces the restrictive plumbing to the throttle body with 2 CAD designed, cross-link plastic air intake feed tubes. Also included with this system is a K&N high-flow reusable cotton flat panel air filter, high temp silicone hose couplers/ hump hose, OEM stainless steel hose clamps and associated fitting hardware. This easy 20-minute installation improves power and sound.
EVO QuickFlow kit OEM Intake System w/ resonance chambers QuickFlow kit installed on a 3.2L Boxster S
Boxster S 3.2L 2000- 3-5 QuickFlow air Intake System INTK98632QF $279
Boxster 2.7L 2000- 3-5 QuickFlow air Intake System INTK98627QF $279
Boxster 2.5L 1997-1999 3-5 QuickFlow air Intake System INTK98625QF $279
© Copyright 2005 - Evolution Motorsports Inc.
Maxandwill is offline   Reply With Quote
